Rhino.Inside Revit Crashes when one scale the viewport
Date/Time: 2024-03-04 23:53:43 -08:00
Application: Revit.exe
Error: Access violation - code c0000005 (first/second chance not available)
Crashed Module Name: d3d11.dll
Exception Address: 0x00007ffbd52fa513
Exception Code: c0000005
Exception Flags: 0
Exception Parameters: 0, 0
Not sure if its the version problem or its just my display settings problem , recent couple of days , I cannot open Rhino.inside revit without it crashing. The thing that triggers it crash is the scaling or changing size of display of rhino, like from 4 views to 1 . Not sure where can I get help …
dmpuserinfo.xml (14.1 KB)
journal.0049.txt (385.0 KB)
Hi. 遲了悔改,
We’ll need more information to be able to help.
Can you provide your About info and a small example or steps to reproduce
Thanks
it just happens when i open any revit model , no matter of the size , and after turning on Rhino.inside, if I try to scale the display port , or change the window size in anyway that can affect the dimension of the display port . It will crash.
That’s an odd one, we’ll need to first troubleshoot by running Revit without any addon/plugins.
I tried the above method Japhy, even with all other plugins disabled , it still crashes in the same way - nothing drawn in rhino, just scaling of viewport and crahses.
I noticed that I only clashed with my external GPU connected , but I have been using it for over two years now. So it went through a lot of versions of Rhino.inside without crashing like this …
RhinoAssemblyResolveLog.txt (169 Bytes)
When in Rhino.inside.Revit can you run the SystemInfo command in the Rhino command line and post the results? Thanks
Rhino 8 SR4 2024-2-13 (Rhino 8, 8.4.24044.15001, Git hash:master @ 5d3f86ffffae3c2ed84d21147c008b3907a40a2e)
License type: Commercial, build 2024-02-13
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET Framework 4.8.4645.0
Primary display: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 3-1-2024 (M-D-Y).
Primary OpenGL: NVIDIA RTX A2000 Laptop GPU (NVidia) Memory: 4GB, Driver date: 3-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.76
> Integrated accelerated graphics device (shares primary device ports)
Secondary graphics devices.
Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 1-23-2019 (M-D-Y).
> External USB display device with 8 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 9-2-2022 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-1-2024
Driver Version: 31.0.15.5176
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.4.24044.15001
can you remove or update your citrix device? These have caused issues in the past.
Is this the latest V-Ray? we should disable this for troubleshooting purposes.
Not sure if this could be related but this windows bug was recently reported in resizing a toolbar.
I am looking at that with company IT on the update on Citirix , will keep you posted.
Disabled Vray too . and used the testerrorcheck command to get some more info for you.
But the RhinoCrash Dump.dmp is too big to upload here , is there anywhere I can sent it ?
RhinoDotNetCrash.txt (1.1 KB)
Try Zipping and uploaded here. Please put a link to this thread in the description.
The RhinoDotNetCrash.txt is pointing towards something windows related.
Yup, just sent it your way. Thanks a lot !
Hi Japhy,
I manage to resolve that issue by turning the gpu on the laptop disable. Might be the issue when things are on one GPU and need to jump to another GPU ?
