Rhino.Inside - From Rhino as generic model
Hi! I need to pass a good number of breps from Rhino to Revit, keeping the information of each element in the properties. Each element/brep, will have its own info and ID code and for that reason needs to be individual.
Directshapes work to pass the ID ans some information, but the properties of the element is limited when comparing with native revit elements.
What would be the best pratice for this kind of workflow?
Hi PRib,
It really depends on your particular needs. There are only a few things on a Generic Model that a direct shape can’t hold, specifically Level and Hosting associations, basically most of the contents of the Constraints group.
