Rhino.Inside for Rhino 8 BETA
Any news on Rhino.Inside for Rhino 8 BETA?
moved to Rhino.Inside category.
We don’t have any nuget packages or guides yet, but…
  • We have compute running on .NET 7 with Rhino 8
  • We have Rhino.Inside Revit running with .NET Framework 4.8 and Rhino 8
It is there, you need to:
1- download the latest daily build for RiR
2- Set your Rhino’s DotNet to Framwork *use the command _SetDotNetRuntime.
you will get this
I was assuming this was a question about Rhino.Inside in general. If this was specific to Rhino.Inside Revit, then Tay’s answer is correct.
oh being alive in the Revit ecosystem , I totally forgot about other Rhino.Inside variants!
Indeed this is not about Revit. I’m updating our code base to .NET 7 and .NETFramework 4.8 for the upcoming Rhino 8 release, and one of our projects uses Rhino.Inside from the NuGet package. I was hoping to get the version for Rhino 8, and I’m happy to see that progress is being made.
Could you possibly share more detailed instructions about this?
Thanks!
Charlie
Just download this latest from here:
https://files.mcneel.com/rhino.inside/revit/dujour/RhinoInside.Revit_1.18.8706.15467.msi
I just found out that the Rhino.Inside nuget package (version 7.0.0) can be used for Rhino 8 inside, by using this code:
RhinoInside.Resolver.Latest = true;
RhinoInside.Resolver.Initialize();
this will find the latest Rhino installed on the system, so even when Rhino 8 and 7 are installed side-by-side it will use Rhino 8. Of course, you need to take care that you reference RhinoCommon version 8.x when doing this.
HTH
