Rhino help mini videos where are they now?
V5
The help tab amongst Properties, layers, materials panel.
Click the video and get error.
something to do with Flash .
To have the help video right there popping up per command typed in is EXCEPTIONALLY USEFUL.
Q1. Where now can I enter the command and see that same video play ?
Also when I bought Rhino V4, there was THE MOST USEFUL DVD with full screen short tutorial videos spoken in the Kings English using Quality screen capture prog,
Q2. Where can one view those same videos, search on a command and the video on that command is found ? i.e Where are all these videos listed to be viewed as they were on that DVD ?
NOT search on a command and get a video of making a shoe, somewhere in that video is that command in use.
Access to help vids should take seconds. we dont have time to view 23 min vid for a few secs that we need.
Cheers
Steve
Hi Steve,
Those clips in the v5 help file are Flash, and Flash is gone, so they won’t play inside the local help anymore. If you rename RhinoHelp.chm in %LOCALAPPDATA%\McNeel\Rhinoceros\5.0\Localization\en-US\Help, Rhino will use the online v5 help instead, where the same command videos were converted to mp4.. Rhinoceros Help
I search for LOCALAPPDATA using AbeMeda which finds anything anywhere C drive, other internals, externals etc.
finds nothing with that name in path or folder etc?
took 10 secs
windows search is still running 10 mins now !
why I use AbeMeda !
If I find it, are you saying to rename the RhinoHelp.something into RhinoHelp.chm
Steve
Hi Steve -
Just copy the following, paste it into the path field in Windows Explorer, and browse to 5.0, etc…
No. The other way around. You need to disable it so that it uses the online help instead.
I had then found AppData/Local/ then the rest of the address
found RhinoHelp.chm with a yellow questionmark over the icon,
also there was RhinoHelp.chw
so I copy pasted that .chw file and gotsuffix copy, then I renamed .chw to chm.
relaunch Rhino and try for a video but it says.
I try for bing but get nothing.
then I see your post Wem.
So I need to disable the .chw and the .chm files, by adding.old
i presume.
Is that it ?
Steve
I don’t have a machine here that can run Rhino 5, so I can’t check.
Japhy said to disable the “RhinoHelp.chm” file. Make that “RhinoHelp.chm.old”.
I can confirm this is working as described.
Hi, OK i disable the chm file.
I now have this
I launch rhino v5 and run help video for railRevolve,
get this
then get this
so no video as such anywhere.
Steve
Windows has updated to block TLS 1.0 by default in newer windows versions. This blocks licensing in Rhino 5, and looks to be blocking you here as well.
Changing back is possible but creates a security issue.
So no help videos for Rhino 5.
however I have dl the video .zip and I am looking at the videos that way now.
so now to solve the tooltips that have been nuked.
(another thread)
and failure to bring custom buttons into V9. to try and use V9.
another thread.
why is Rhino a rough ride ?
and the lines
Steve
Hi @Steve1
I tested Rhino 5 64-bit on a Windows 10 system with the RhinoHelp.chm file renamed, but I couldn’t reproduce your problem. What version of Windows are you using?
The help panel uses the old Internet Explorer. Try these steps reset it.
  1. Open Microsoft Edge.
  2. Copy and paste the following line to the address bar to open the page.
    edge://settings/defaultBrowser
  3. Select Internet Options to open the Internet Properties dialog.
  4. On the Security page, click the Reset all zones to default level button.
  5. On the Advanced Page, click the Restore advanced settings button.
  6. Run Rhino 5 and see if the problem is fixed.
NOT working.
I’m sorry, but this is beyond my knowledge.
