RhinoGaussianSplattingPlugin is a C# integration plugin for Rhino 3D that allows users to import, visualize, edit, and convert 3D Gaussian Splatting datasets and standard point clouds. The project enables real-time viewport display, custom boundary-based cropping with undo support, automated surface extraction (meshing), and synthetic splat generation (baking) directly from active Rhino geometry. Import: .ply, .las, .splat, .ksplat, .sog, .ssog (.zip), .spz and webp image Export: .ply, .splat, .ksplat
This looks like a very interesting plugin.
I couldn’t find RhinoGaussianSplatting Plugin anywhere.
Is it publicly available, or is it still under development?
If it is available, could you please share where it can be downloaded?
Also, I was wondering what dataset was used for the video and screenshots. Was the Gaussian Splat generated from your own photos, or did you use a publicly available dataset?
Thank you for the information! That explains why I couldn’t find it on Food4Rhino.
I’ll have a look at the SuperSplat examples and the ComfyUI + TripoSplat workflow.
I’m personally interested in Rhino × GIS integration, so I’m curious to see how this plugin could fit into that kind of workflow.
Please let me know here when the plugin is published!
Thank you for sharing!
I’m planning to explore your plugin as part of a Rhino × GIS workflow. It will be interesting to see how it performs with geospatial data. I’ll share my findings here once I’ve had a chance to test it.
Just received my scanner that also can produce 3D Gaussian splatter objects.
So this plugin came at exactly the right moment! Thanks, I will start testing.
First test of scanner and plugin.
More tests will follow, I have to become more familiar with the scanner, light conditions and what I can do with the plugin.
But both already make me happy!
attached the scan of my old teddy bear BeertjeSplat.3dm (1.6 MB)
Do you need the .splat file? The gaussian splat is not in the .3dm file? I cannot upload a .splat file here, it is not allowed.
Can I send it to you personally?
This is how it looks on my pc. pointclouds in 3 windows, and as a splat (?) in the perspective window.
