Rhino Gaussian Splatting
Given that the Rhino 9 Beta signals a shift from OpenGL to Direct3D, do you have migration to the latter on your roadmap?
For now opengl only
Yes, it created a mesh. I did not check any options.
any chance to make it possible to render the gaussian splats in the rhino renderer ? (would be also nice to be able to relight the splats and react to shadows, etc.)
This would need to be supported by the Rhino developers. There’s nothing I can do about it from the plugin side.
another thing i found out is that it seems to render the last importet splat infront of the ones before, not regarding the perspective
Splats use a custom preview. When their bounding boxes collide, you can get this kind of incorrect draw order.
I already tried to find a solution for this.
Thanks again for sharing the plugin.
I’ve now had a chance to test it with a Gaussian Splat of Mont-Saint-Michel.
As an experiment, I combined it with Heron and aligned the splat with a WGS84-based geographic context in Rhino, adjusting its position, orientation and scale.
It seems like an interesting way of bringing non-georeferenced 3DGS data into a Rhino × GIS workflow.
Here is the result so far.
Data used:
Mont-Saint-Michel 3DGS: SuperSplat
French administrative boundaries: Admin Express COG (WGS84 / EPSG:4326), data.gouv.fr
Very nice !
Thanks!
But I noticed that Move / Rotate / Scale applied to an imported Gaussian Splat reset after reopening the Rhino file. Is this expected?
This is important when using GIS data to position a splat at its real-world location, as the alignment needs to persist between sessions.
Thanks
Problem fixed, try it and let me know
Thanks, I tested it again.
Scaling alone is now saved correctly after reopening the 3DM file.
But [CropGaussianSplat] is still reset after reopening, even when no other transforms are applied.
So it seems the remaining issue is specifically with persisting the cropped splat state in the 3DM file.
That fixed too, check the new update
Thanks for the quick update!
I tested it again, and the cropped splat now persists correctly after saving and reopening the 3DM file. The Move / Rotate / Scale transforms are also retained, so the issue seems to be resolved.
This makes it much more practical to keep a 3DGS dataset aligned with its real-world GIS context across sessions in a Rhino × GIS workflow. Thanks again for the quick fix!
This is untrue. It’s just that macOS will translate the openGL calls into Metal ones. I’ve made dumb little games with C++ and OpenGL that are cross-compatible on Windows, maxOS and Linux.
ِCan you test this in macOS
RhinoGaussianSplatting_MacOS.zip (474.6 KB)
for me it always draws the last added gaussian splat in front, no matter if the bboxes collide or not
Do you use the latest version?
ah no i haven’t … thank you !! with the latest Version it wokrs :smiley:
Added support for orthographic views.
