Rhino for Mac - irregular grid bug (metal)
The grid is irregular while metal is enabled. Works fine when metal is disabled - via TestMetal command.
Does anyone know if there is a fix for this?
[ metal disabled ] works fine
[ metal enabled ] irregular grid
( view the screenshots in full size to see the difference )
system info :
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15002)
License type: Evaluation, Build 2024-01-09
License details: Cloud Zoo
Expires on: 4697046-12-02
Apple macOS Version 14.2.1 (Build 23C71) (Physical RAM: 16Gb)
Mac Model Identifier: Macmini9,1
Language: de-DE (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1
LG HDR WQHD (3440 x 1440 @ 60.00Hz)
Hello- I see this as well with a very dark background. Thanks for the report.
RH-80246 Grid display messy with high contrast
since todays patch this problem has become worse.
The grid is still messy (not fixed) when metal is enabled.
When disabling metal the viewport gets completly black, everything disappears.
I would love for the grid problem to be solved asap since it’s such an essential feature.
:raising_hand_man:
Hi Aldin -
Please run the Rhino SystemInfo command and copy-paste the result here.
Hi Wim,
thanks for answering this fast.
:raising_hand_man:
System Info :
Rhino 8 SR8 2024-6-11 (Rhino 8, 8.8.24163.12482, Git hash:master @ ded4d86ca901dbeaf13ee84f79b3e91b22da4880)
License type: Educational, build 2024-06-11
Apple macOS Version 14.5 (Build 23F79) (Physical RAM: 16GB)
Language: en
.NET 7.0.0
Graphics processors
Apple M1
USB devices
Apple Inc.: Apple Watch Magnetic Charging Cable
Apple Inc.: Apple MagSafe Charger
Logitech: USB Receiver
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.8.24163.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.8.24163.12482
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.8.24163.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.8.24163.12482
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.8.24163.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.8.24163.12482
Hi Aldin -
The fix for RH-80246 went into the first public release of 8.9 a few hours ago. You’ll have to change your update frequency from Service Releases to Service Release Candidates to get this version.
Hi Wim,
I installed the Service Release Candidate and it works perfectly.
I am stunned, thank you wim, thank you guys, the support is awesome.
:raising_hand_man:
hello frens,
the bug above is back. exactly the same behaviour.
version:
Version 8 (8.36.26258.13002, 2026-09-15)
Hi Aldin -
Thanks
I’ve reopened this → RH-80246 Display Metal: Grid display messy with high contrast
RH-80246 is fixed in Rhino 8 Service Release 38 Release Candidate
