Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 8-21-2020
Driver Version: 27.20.1034.6
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 4 GB
well Safe mode systeminfo doesn’t tell us anything since it can’t collect info from your video card, but you should start by updating your video drivers and your Rhino 6 is also very out of date–and possibly not legit??
Render version: 0.0
Driver Date: 1-18-2021
Driver Version: 27.20.14527.2002
C:\Program Files\Rhino 6\Plug-ins\Trace\Trace.rhp “Trace” 1.3.0.0
D:\Google Chrome Downloads\topmostviewport.rhp “TopMostViewport” 0.9.1.1
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
D:\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.0.20314.3001
D:\Rhino 7\Plug-ins\rdk.rhp “Renderer Development Kit”
D:\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.0.20314.3001
D:\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.0.20314.3001
D:\Rhino 7\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
D:\Rhino 7\Plug-ins\NamedSnapshots.rhp “Snapshots”
D:\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.0.20314.3001
D:\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.0.20314.3001
D:\Rhino 7\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
D:\Rhino 7\Plug-ins\Displacement.rhp “Displacement”
For starters you should update to the latest SRs for both V6 and V7…
Once done, your SystemInfo will probably be more informative about what the problem is…
That being said…if I were to guess … it looks like you’re probably plugging your monitor into the non-discrete GPU located on your motherboard (i.e. Intel)… Which causes Windows’ Main Display to always be the Intel GPU. If you have more than one monitor, then you need to make the monitor that’s plugged into the AMD GPU the “Main Display” using Windows’ Display Settings.
Again, the latest SRs will pretty much tell you this if that is the case. If it’s not, then it will probably have more details on the real problem. Please update to the latest SRs and then run SystemInfo again.
