Hi everyone !
Can anyone explain what are environment maps and how do we use them?
Is it also possible to use them along bump and texture maps?
Thanks!
L
Hi Leyla - the environment map in a Rhino material is mostly used to mimic reflections from an envronment. The projection used in the mapping favors a ‘chrome ball’ type image for the environment for the most realistic mimicking of reflections-
here is a chrome ball image:
At low ‘concentrations’ this can be used to add a bit of life to shiny materials
and at higher numbers can mimic chrome or mirrored surfaces.
This is not accurate like a raytraced environment in a reflective material but is a good cheap substitute that does not use a lot of machine resources to render in a viewport.
These can be combined with any of the other channels like bump etc. though these would generally not use a chrome ball, I guess.
