Rhino doesnt start
i installed rhino on windows laptop (gaming beast). i am completely new to rhino and when i double click the icon, it doesnt respond at all. Could someone help with this issue? i managed to run rhino before on my laptop. now it doesnt start at all, not even an error message. so frustrating
The only possible way to turn on your rhino back is Uninstall & Reinstall. Try this.
Why are you sure he needs to uninstall and reinstall?
@davidcockey Even I faced this kind of issue. For me Uninstall/ Reinstall turns as a solution not now. A long back with my old PC. So I suggested it. Or else someone need to remotely control his PC and check error.
it didn’t work and only problem with rhino. no problem with running other modelling tools. before rhino was also working, i do not know what happened. i installed and uninstalled several times. please help.
Hi - have you tried running Rhino in Safe Mode?
Which version of Rhino?
I am trying to install 6.25.20114.05271, it is saying successfully installed but not starting at all, even tried in safe mode, nothing, i want to buy it but if this is the case then it is just wasting money.
the problem is rhino is not giving any error also, it is just not starting
This won’t fix it, but it should generate a file we can review to see where Rhino loading is failing:
https://wiki.mcneel.com/rhino/crashhelp/lastresort
Hi there !
I did all the steps in your provided link (Diagnosing Rhino Startup Errors [McNeel Wiki]) but its not creating the file to be checked… i contacted through email to Mcneel and they told me to try reinstalling, running troubleshooting, and restarting the license, but it’s still not working for me, any other ideas i could try?
Thank you for the time
Hi, @Mariah_Rhino when Rhino fails to start, I assume you mean it installed fine, but sill not launch-
are you on a mac or a pc?
if on a mac, do you have enscape installed? if so see this thread-
if you are on a pc and are not using enscape, see this thread-
Let us know if either of those fixes do not work,
you are welcome to email us directly at tech@mcneel.com for a support ticket or call us as 206-545-6877
Hi , thank you for the fast reply.
Yes, It’s installed fine but won’t launch. Checking the task manager, the computer is not even thinking or processing when I try to open it.
I’m on a laptop with Windows 11, no enscape, trying to use Rhino6.
I just tried the second solution you offered and read though the posts but still nothing, the program isn’t starting. Do you have any other ideas?
I sent an email to tech@mcneel.com but the options they provided aren’t working either
hi @Mariah_Rhino
I think it is easier if we try to solve this issue through a single support channel. Let’s continue the discussion via email support.
Alright, that’s fine for me.
Tech support suggested reinstalling the microsoft c++ redistributables, but still nothing, rhino won’t start. Any ideas?
hi @Mariah_Rhino see email.
