Install rhino 8
Hello, and good day! I have been using Rhino 8 for a long time, but suddenly it stopped working. I uninstalled it and reinstalled it on my system, but it still doesn’t work. I’ve repeated this process several times and tried different methods for uninstalling and reinstalling it. What could be the problem?
we’ll need a lot more to go on to offer any useable help…
are you using a mac or pc?
what does “still doesn’t work” mean?
won’t launch, won’t run, runs but freezes, runs but crashes?
does Rhino start in safe mode?
more details please-
I’m using a pc
Rhino won’t launch on my pc
rhino doesnt work in safe mode
rhino 7 install on my pc and work well
are you getting any error messages or does it simply not launch?
I assume it did in fact install successfully, but it just won’t launch? Or did it have errors on install?
any virus protection that may be blocking Rhino?
Lets check to see if a windows update hosed your .Net install and try switching Rhino 8 to .NetFramework for troubleshooting.
To start Rhino in .NET Framework once:
Caution: only recommended if you have a plug-in that doesn’t run in .NET Core.
  1. Create a new shortcut for Rhino in Windows
  2. Edit the shortcut
  3. Add command line argument /netfx
