Rhino crashing when opening with error message
Since updating the GPU Tessellation on Rhino to try and resolve lag and freezing, I cannot open Rhino.
The programme loads to the log in window, opens then crashed within a few seconds. it displays an error report. (See image)
I have tried uninstalling and repairing.
Rhino works in safe mode.
Any suggestions would be appreciated.
In safe mode go to your GPU settings and change back to the original and disable all 3rd party plugins.
In document properties>Plugins you can filter by 3rd Party plugins only.
Thank you!
I think this has worked. (Finger crossed)
Rhino has managed to open but I have lost the plugin needed. I have turned it back on but it’s not coming back… Veesus is the plug in
Please type in SystemInfo into your Rhino command line and post the results. Veesus should work in 5,6 & 7, if its not working in 8 you should try switching to the .Netframework.
