Since this last update we’ve been having some problems when selecting sub-objects, either on surfaces or subds. For example when trying to select a surface edge, it’s taking longer than usual. If there’s a couple of objects close to each other and I try to select one of them, the menu to pick which to select takes about 2-3 seconds to popup. Right now I’m working on a subd model and when trying to select a ring, I was trying to select just one face and it’s not working, I had to move or rotate the model to be able to even select a face. Then trying to select a couple of faces to select an entire ring, Rhino crashed twice.
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 5-19-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.96
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-19-2022
Driver Version: 30.0.15.1296
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Hi Juan - so just to be sure - please try the following: start a new file using ‘No template’. Make a box or SubD box or two - does the subobject selection problem arise?
We tried to replicate it with new files using templates and the “no template” option and everything works fine. Problem’s only with “old” files, even if we add new stuff. We also tried selecting some components, copying them to a new file and it seems that the problem travels with them.
Hi Juan - you show a lot of non-default plug-ins, I don’t know if there is plug-in user data getting into the mix - one test would be to open one of the ‘bad’ files and SaveAs with no plug-in data, to a new name, of course, and then test the resulting file - any different?
one thing to check, the rtx cards have a studio driver and a game ready driver. Some systems work great with one, some systems with the other… I have not been able to determine what makes one work and the other not.
which ever one you are using, grab the other and when you install use the custom/ clean install option. and give it a go…
