Rhino crashing like hell
Hi everybody, my rhino is crashing like hell and blocking the pc, I have to turn it of violently…
It happens from when I installed the latest versions of visual arq…
Any help?
Thanks
I installed both version (latest Relaease 1.9:x and the Canidate 2). I don’t have crash or something like that.
The only thing is, that in the canidate Version it is impossible to change the strength of the roof
edit: moved to VisualARQ category
Hi @arkfavero,
Do you know how to reproduce the crashes?
Are you sending the crash reports to McNeel?
Regards,
Enric
  • trying to open visualarq object properties right clicking on the icon…
  • in rendered wiew, passing from 1 to 4 views and trying to use another view, as if the rendered view parameters were too heavy for the system (hp zbook15 with quadro gcard)
  • quite random the problem is
No reports to mcneel, as when it happens, I have to turn down completely by long pressing laptop start button…
should I reinstall rhino completely?
Hi @arkfavero,
Have you tried to uninstall VisualARQ?
Does this happens on all documents even on a empty new one?
Regards,
Enric
Rhino crashes when save as/ export? Did you place Some IFC tags ?
