Rhino crashes when adjusting opacity in material 'colour' channel
I keep getting a crash when I try to adjust the opacity of a texture in the colour channel. Usually this would let me blend the texture with the base colour of the material in order to adjust it’s appearance (darken or lighten, change the colour temp slightly
etc).
Steps:
1 - Create a new custom material.
2 - Assign a texture image from my files in the colour channel.
3 - Attempt to change the opacity of the texture by clicking on the button/slider on the right.
4 - Rhino freezes and after a few seconds crashes.
Have tried with different image files - same problem. I’ve tested the other channels and they seem to work fine. But Colour crashes the program every time.
Please post the results of the Rhino command _SystemInfo.
Hi Nathan,
Rhino 8 SR4 2024-2-13 (Rhino 8, 8.4.24044.15001, Git hash:master @ 5d3f86ffffae3c2ed84d21147c008b3907a40a2e)
License type: Evaluation, build 2024-02-13
License details: Stand-Alone
Expires on: 2024-05-04
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Unplugged [89% battery remaining] ~208 minutes left
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 3-17-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.15
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-17-2022
Driver Version: 30.0.15.1215
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.4.24044.15001
I am experiencing the same problem everytime. Has there been a solution?
@Tania_Utomo you probably should start by mentioning the output of the Rhino command _SystemInfo
