Rhino Crashes in Monochrome
Hello dear Rhino team,
Rhino crashes in monochrome mode on my computer. After about 2-5 minutes in 3D view with monochrome mode enabled, everything freezes and the only thing that helps is a hard reset of the laptop.
The Windows event log says Kernel 41.
Is this a known issue? Should I just avoid using monochrome on my laptop with integrated Intel graphics, or is there a workaround?
Thank you very much in advance.
Best regards,
bredewin
Rhino 8 SR27 2026-1-19 (Rhino 8, 8.27.26019.16021, Git hash:master @ a7029e543145704b986eede4bc40b6bd8a0645d0)
License type: Educational, Build 2026-01-19
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 23GB)
.NET 8.0.17
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display and OpenGL: Intel(R) Arc™ 140T GPU (12GB) (Intel) Memory: 2GB, Driver date: 11-26-2025 (M-D-Y). OpenGL Ver: 4.6.0 - Build 32.0.101.8331
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
  • Secondary monitor attached to adapter port 1
    Primary OpenGL: Intel(R) Arc™ 140T GPU (12GB) (Intel) Memory: 2GB, Driver date: 11-26-2025 (M-D-Y). OpenGL Ver: 4.6.0 - Build 32.0.101.8331
Integrated (slow!) graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 3.3
Anti-alias mode: 2x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 32.0.101.8331
Driver Date: 11-26-2025
Driver Version: 32.0.101.8331
Z-Buffer depth: 24 bits
Total Video Memory: 2097148 KB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.27.26019.16021
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “LeerlaufProzessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.27.26019.16021
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.27.26019.16021
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.27.26019.16021
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.27.26019.16021
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.27.26019.16021
Lets turn this up to max
First of all, thank you for your efforts.
I tried it and it worked for maybe 30 seconds longer before freezing up again. Is this a general problem with Intel in monochrome mode? Would completely reinstalling the laptop help?
edit: Oh, by the way, I figured out that it’s because of the shadows (but without shadows, it’s somehow not the same).
