My rhino just crash when I was working without never saving (so it was a new drawing), when I opened It, it could open the autosave file without any problem because it ask me to do so when I opened the application. The problem is that it crash like 1 min after I open the autosave file and now there is no autosave file… Do you know where I can found it?
the files do not end up in the trash as you suggested, i just checked, not saving a file working for a while it goes to /Users/****/Library/Autosave Information, when rhino crashes the file remains there.
but when you restore that autosaved file work for a few moments on it the file disappears out of that folder, and that seems to be the end of that file.
@victor_girardet you better start saving files when you work on them the moment you have started putting work into it. best you save it when you open it then the file will have a place and the autosave can act.
sorry, I edited my response as I noticed you are on a mac.
you can use versions to go back and grab older files from time machine on the mac. see my updated response above. and again, if you don’t have time machine set up PLEASE DO IT NOW!
thanks you very much time machine works. At the beginning there was nothing between 10:48 and now but after that it appear so I found my folder at 15:00
