Rhino Camera Advanced Question
Hello everyone,
I am trying to do a script which might be weird. Pls check the pics below as to explain what I wanna do. In short, I am thinking a way to transform the edges of geometries to a plane, where the 2D edges will perfectly match their parents in 3D scene:
The middle plane is where I want the 2D edges(shown in blue-ish) to be projected from 3D geometries.
As you can tell, the blue-ish lines are mismatched somehow and I figured the issue might be my projecting 3D wireframes directly to the plane JUST by sole vector, the Normal of the camera point plane.
So, I guess there must be an equation to transform wireframes of 3D models to a certain plane, which in 3D view port they two can be perfectly matched?
Thanks,
Lei
Hi Lei,
If I understand your question correctly, the geometry shouldn’t be projecting along the normal of the camera point plane, but in a cone shape, down into the camera origin point.
The image you shared actually shows this shape - not as a cone but as a pyramid coming out of the camera.
(ie. Use “Extrude to Point” rather than “Extrude by Vector”)
Maybe the scripts in this discussion can help, it sounds like you are trying to do the same thing:
Thanks porral, it works!
