Request for two new options in the Project command or new command(s):
Project to a point: For a curve this would be the same as ExtrudeCrvToPoint and then intersecting the extrusion with the target surface. For points it would be the same as creating lines between the points to be projected and the “to point” and intersecting the lines with the target surface.
Project to the camera: In a perspective view this would be Project to a point with the camera location as the point. In a parallel view this would be the same as the current “View” direction option in Project since the camera location is an infinite distance from the objects. This option is useful because it allows the user to position the view with the projection in the desired location on the target surface before projecting.
