Rhino/Bongo Animation Freezes
I’m using Rhino Version 8 SR35 with Bongo 3.0 WIP 21. When I try to render an animation of 150 frames at 30 FPS in Full HD (1920×1080), using either Viewport Display (in Monochrome or Pen display mode) or Rhino Render as the target render, the process freezes after frame 19 of 150. Is there a known fix for this? What is the problem?
BTW, I experienced the same freezing issue with Bongo 2.0 as well.
Thanks!
Are you rendering the same model?
If so, would you be able to share the model with us?
You can upload it to:
https://www.rhino3d.com/upload?to=marika.almgren@mcneel.com
I just tried rendering animations in Full HD and I’m not able to make it freeze.
This issue was caused by a display issue in Rhino and should be fixed in Rhino 8 SR 37, if anyone needs a fix for this before SR37 is officially released, feel free to PM me.
RH-98631 is fixed in Rhino 8 Service Release 37 Release Candidate
