I keep having the same issue with Rhino where I will be modelling in 3D and then rhino will lag for a second and then all screens turn black. I usually can still save the model but then have to restart Rhino to work on it again. The model then reopens but the same thing keeps happening. I am usually in shaded mode in 3D with all my other views set to wireframe. I have been using Rhino for 10 years and I know that the model is not damaged or complex. It’s an 11mb file that I am currently working with. My laptop specs are fine, not amazing but definitely enough to cope with a small rhino file. Does anyone have any ideas why this is happening.
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 7.8Gb)
Primary display and OpenGL: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 27.20.100.9664
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 27.20.100.9664
Driver Date: 6-1-2021
Driver Version: 27.20.100.9664
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Users\Fin\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22290.1357
Id like to add that I also read on a forum that someone was having a similar problem when they were using a second screen (which I am). However, I have the problem when I am just using rhino on my laptop without the second screen plugged in.
