What is BETA? We’re not adding any new features, nor are we making significant changes to the UI. We’re also done breaking the APIs, so plug-ins written for this Beta will work in the commercial release of Rhino 6.
For the next few builds, we’ll be wrapping up documentation, localization, and working with our third-party developers to get their plug-ins ported to Rhino 6.
New this week:
Feature:
- Menu: Add UpdatePlugins command to menu (RH-42842)
Crash:
- Print: RhinoCore!CRhinoPrintInfo::DisplayAttributes – Access Denied (RH-42050)
Bug:
- Annotation: Add RTF parsing support for \bullet (RH-42914)
- Annotation: Leader: Leader created with Python script not selectable (RH-42865)
- Annotation: Text: V6 text not round-tripping to V5 (RH-42957)
- Core Architecture: Memory leak in Rhino 6: ON_Font::Internal_SetFontDescription opennurbs_font.cpp Line 2813 (RH-42455)
- Core bugs: Track down memory leaks in Rhino 6.0 (RH-42444)
- Display: Making a copy of a Technical viewport creates some kind of ghosted residual background (RH-42911)
- Display: OpenGL 3.3: When core profile is enabled, Rendered mode has ghosting issues. (RH-36343)
- File IO:
- GhostedViewport: World icon off causes artifact in ghosted mode (RH-42635)
- Grasshopper: Distinguish Offset and Offset Loose (RH-42725)
- Help: Raytraced display mode Help should indicate where the mode can be controlled other then the Display panel (RH-42667)
- Insert: Dialog does not allow scale factors < 1 (RH-42746)
- Installer: Tile uses WIP image (RH-42786)
- Licensing and Validation: Credentials expired flow confusing (RH-42217)
- Localization:
- Length command prompts in English (RH-42256)
- NetworkSrf command > Surface From Curve Network dialog - title gets truncated (RH-42757)
- Rhino incorrectly sets locale ID to 1033, causing downstream problems (RH-42826)
- Some strings in Licensing dialog are in English, and the dialog needs resizing (RH-42804)
- Make2D: Too many materials (RH-42848)
- OpenNURBS: ONX_Model Write function fails with big files (RH-42943)
- Patch: Unsafe cancel (RH-42942)
- Rendering: Realtime SDK: Different mappings used in Raytraced degradation mode (RH-42783)
- SDK:
- SDK: RhinoScript: DocumentData is not saved (RH-42888)
- TextObject:
- What: Should report Nurbs forms of circles and arcs (RH-34846)
Cosmetics:
- IncrementalSave: Naming problem (RH-42621)
- Toolbar: Drag Strength icon is not anti-aliased (RH-42705)
Download Now and report any problems in this forum.
