Rhino -> AutoCAD - How To Maintain Sub-Layer/Parent Structure?
I am using Rhino 8 and saving a .3dm file as a .dwg to share with an engineering partner.
It opens fine in AutoCAD but the layer structure is not maintained.
Specifically if, in Rhino, I have some layers such as Commercial, Parking, etc. as children of SITE
The hiearchy looks like SITE::Commercial, SITE::Parking, SITE::etc.
However, when opened in AutoCAD with the different export options I can only get the child layers by themselves, Commercial, Parking OR with a dollar sign symbol replacing the double colon ::
So, in AutoCAD they read as SITE$Commercial, SITE$Parking
Am I overlooking something simple?
Honestly, it’s been years since I’ve touched AutoCAD so I’m not familiar if there’s a simple process to use the $ syntax to merge the proper layer structure or some other setting I am overlooking.
Rhino Layer Structure Example:
How it is in the .dwg in AutoCAD:
Thanks for your help!
You could create group filters:
Search/Filter your layers:
Note the asterix placement.
Then you can select those layers and drag them into your new group filter (do like a shift+select, CTRL A works too I think):
Closest I can come to a solution to sort your layers. I was a bit miffed myself the first time I ever imported layers into AutoCAD. And I’ve since been trying to come up with a scheme that’s cross-compatible.
Thank you @keithscadservices,
Well this is certainly helpful and I can utilize it in the meantime I am shocked there isn’t better interoperability with the layers from Rhino to AutoCAD as all the other properties (Visiblity, Color, etc) transfer just fine.
I would think the parent,child,grandchild hierarchy would be a give in but I’m not a programmer so who knows.
@Gijs are there any open youtracks or requests that you know of to have Rhino to .DWG maintain layer structure?
Thank you all!
Hi @michaelvollrath,
Given that AutoCAD does not have hierarchical layers, how do you see us improving interoperability?
— Dale
One thing would be to add an option to re-create the sublayer structure in the Rhino DWG importer when the layer names contain some ā€˜@’.
I think it’s on the list.
Btw: why does it have to be an @ sign? Seems to be hardwired in the exporter. Make this configurable? A :: would look better, for example.
I can make an AutoLISP script fairly easily that would change the layer names. I’ve also created this less-than-elegant solution:
@Eugen The exporter from Rhino to AutoCAD uses a dollar sign $ for delineation between parent/child.
@dale thanks for your response, I could have sworn CAD supported layer hierarchy but obviously it does not, you are right.
Is the $ dollar sign syntactically important? Or is there an opportunity for a user defined delineator such as - or :: or whatever the user would type as the delineation string?
@keithscadservices well a script structuring the layer hierarchy with append text as you show seems like that’s maybe the best option for now because at least then you have hierarchical layers together in ā€œgroupsā€ and they still retain alphabetic sorting.
I’d love to test out the AutoLISP script if you’d be willing to write/share.
Thanks!
Right, thanks! Not too much prettier… =)
I do agree, it does not promote great legibility which is why I’m curious what it is doing from a code/syntax perspective
