Wish: recreate sublayers by DWG importer
Hello!
DWG/AutoCAD does not support sublayers, hence the Rhino DWG exporter converts them into parentlayer$sublayer1$sublayer2…
Would it be possible to add an option to the DWG importer to recreate the sublayer structure by given separator character? (“$” by default, but ideally, it’s a choice)
Also discussed here.
Simplifies roundtripping Rhino/AutoCAD, which is (still) very common.
Thanks a lot!
Hi Eugen -
This request is on the list as RH-66996 File IO: Create nested layers from DWG files
RH-66996 is fixed in Rhino WIP
Thanks, confirmed working! Sweet!
