Rhino arctic mode not working
My Rhino does not give me the right arctic mode anymore since I was playing with some meshes in grasshopper yesterday.
Since then, I have tried…
  1. restarting computer
  2. _ClearAllMeshes
  3. restore default for arctic mode
  4. starting a new file with simple box.
Has anyone had the same issue or know how to fix?
Hi -
Please start by running the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR2 2021-1-21 (Rhino 7, 7.2.21021.07001, Git hash:master @ 96ff97351fbdf5d2acdeaf781aea1577f2ff60f7)
License type: Commercial, build 2021-01-21
License details: Cloud Zoo
Windows 10.0.19045 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Secondary graphics devices.
NVIDIA Quadro P600 (NVidia) Memory: 2GB, Driver date: 1-5-2022 (M-D-Y).
> Accelerated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
ATTENTION:
Desktop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
There is only one monitor detected, but it’s connected to the slower, integrated graphics video port.
  • Recommended: Unplug the monitor and plug it into one of the video ports on this device:
    [NVIDIA Quadro P600]
  • Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 1-5-2022
Driver Version: 30.0.14.7298
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 2 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.2.21021.7001
Hi -
First of all, the current version of Rhino 7 is SR32 - you are running SR2. Please update Rhino.
Apart from that, it appears that something has happened to the GPU configuration on your system.
Between those two lines, I would expect there to be some “primary” device.
Also, you are currently running on software emulation of a GPU:
You’ll to find out which GPUs you have on your system and install the most up-to-date drivers for those.
(post deleted by author)
