Rhino animation not capturing the whole model
Hi all, I’m still in the process of figuring out Rhino’s animation tools and I’m struggling to figure out saving an animation for a project. I’m not using any extension, just the regular animation settings in Rhino. I’m not very experienced so any help with this would be great.
I used the SetFlyThroughAnimation to make it, and when I play it everything looks all well and good. However, when I eventually record the animation and export the frames a lot of the things in the background end up missing or get cut off.
I think there’s like a boundary that’s cutting off things that are far away? This issue doesn’t come up when I export less frames, but I do need a higher framerate for this project. I tried increasing the number of passes but honestly I have no idea if that does anything.
I’ve never done this before so if anyone has some advice for getting this to turn out I’d really appreciate it. I’ll add a screenshot of a frames vs. a screenshot of the model.
A frame from the animation
A screenshot of the model.
If anyone has any ideas, I’d really appreciate it! Thanks!
Summary
This text will be hidden
That looks as if a clipping plane, beyond which nothing is shown, is in use, or a camera/target problem. Maybe this thread where users report similar issues is of use.
Hi Julia -
This bug is on our list as RH-77918 RecordAnimation clips geometry
I’ve added your thread.
