Another question.
If I use land design for AutoCAD, and place there some tree blocks from the land design collection, when i import the model in Rhino will land design recognizes the objects or I should replace them?
No… they’ll be imported as block instances. The plugin data is lost during the process.
Since overcoming this limitation requires a huge effort, I think it will be implemented only if a lot of users ask for it.
ok, I think this isn’t so important. I am just going to civil 3d for terrain creation with advanced tools. For sure more important is to extend terrain capabilities. Instead, I saw a videο sending objects to Revit. Are you able to send only the mesh or also plan symbols? What about textures? Will they render in enscape inside revit?
