Hello, I have another weird thing with dimensions. They tend to dissappear when viewed from certain angle in perspective view. Perhaps it has something to do with the option “Orient text toward reader when viewed from behind” - when this option is “off”, it doesn’t happen (but the dimensions are unreadable then). Example screenshots:
Hi - I’m not able to reproduce this on my system with a simple test.
Could you (1) post that file, and (2) run the Rhino SystemInfo command and post the result here?
Thanks!
Thanks! I’m curious about the result. Just to add: this issue doesn’t happen always, perhaps it has something to do with some specific setting or file history. At some models it works well, at others it doesn’t.
