Dimension text visualization issues
Hi there,
I’ve been experiencing a weird visualization “cut” with the dimension text.
I tried to change size and position but nothing changes, basically the text is cut at mid height and sometimes it is almost imossible to read the number.
I attach a ic to make it clear
Thanks for helping!
In a situation like this it’s practically mandatory to attach the file from the Systeminfo command so potential helpers know the exact version of Rhino and configuration of your computer.
Is this the file you need?
Rhino 6 SR1 2018-1-23 (Rhino 6, 6.1.18023.13161, Git hash:master @ 92a80e9e2b29e4670a94deb0d656e234ca1fe036)
Windows 10.0 SR0.0 or greater (Physical RAM: 7.9Gb)
GDI Generic (OpenGL ver:1.1.0)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 5-19-2016
Driver Version: 9.17.10.4459
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 2108 MB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
your driver looks very old, might be worth updating, its not a very strong card either, but should still be ok for basic linework, modelling, and annotating etc. I’d definitely try updating the graphics card driver and see how you go
I’ve checked, but there is no update vailable for my graphic card (I’ve also installed the intel “update checker”). Is there anything else I could try?
Hi -
A few things here…
  1. creative reporting likely hides the fact that you are running a cracked version?
  2. SR1? Rhino 6 is on SR35…
  3. You don’t appear to have a GPU in that machine at all… That’s not a supported configuration.
