Rhino account login seems to be down
Hi @wim and @pascal, I am trying to download Rhino 8, but can not log in to Rhino Accounts (https://accounts.rhino3d.com/) but it just hangs, clicking on the “email me a login link” fails too.
Can you please try again? The system was just restarted, since it had some problems.
Hi Marika.
Thanks, I just tested now, and nothing happens, it just doesn’t respond and rests on this page:
Hei Jørgen -
It looks like we have some ongoing problems with cloud zoo. This is being looked into.
Hi @Holo, this looks to be unrelated to the problems that we had with Cloud Zoo earlier. If you go to https://accounts.rhino3d.com in a different browser (or on a different device) and attempt to login, do you experience the same behaviour (where hitting enter or clicking on the “>” button does nothing)?
I have had this behavior many times in the recent past. I think I made a post about it. Sometimes hitting the arrow button does nothing, no matter how many times you hit it. Often I find if I delete the stored password (Chrome) and input it again manually it works to log in. Even though the stored password is identical to the manually re-typed one.
I tried that too, but my edge browser also had the data stored, and it failed. I also tried manually typing in the passwords manually in both browsers.
This worked, I use Crome too. Thanks for the workaround, very strange behaviour and I can confirm that I used the exact same password as the stored one, and I could not find any errors in what was stored for the site.
I guess this will be a tough bug to track since we now have deleted and recreated the login data.
I’ll tag your reply as the Solution Mitch, even though it isn’t :wink:
Definitely isn’t, and still happens to me fairly often.
Thanks for this @Helvetosaur! Agreed that this is not a solution, but it will hopefully be useful in trying to track down the real cause of the problem.
@Helvetosaur are you still seeing this issue? I made some changes last month that should hopefully have stopped it from happening.
