Rhino 8 WIP - undo seems broken
using rhino 8 WIP:
Work In Progress
(8.0.23136.12095, 2023-05-16)
I noticed, that the Undo function seems to be broken. Whatever I do, once I press CTRL+Z, I get the message in console informing me, that there’s nothing to undo, even with basic functions like move.
Cheers,
Ivan
Hi Ivan - is this true with a new file and just say a box added? Can you please run SystemInfo in Rhino and copy/paste the results here?
Hi Pascal. It seems to work in a clean scene, I might have jumped the gun with my preemptive bug report. I’ll try to investigate the scene that’s giving me trouble a bit more thoroughly and get back to you ASAP
I’m having this same issue. Just downloaded the Beta with some great new features but Ctrl Z is not working. Edit undo is not working.
Hi Norma -
Next time I’m open and working on it will do. There are a couple of quirky things going on and I’ll make sure to run system info each time. Thank you.
Yes same here, not always working
Hi Norma -
Make sure to start new threads for different topics.
Hi Jonathan -
Same issue here.
I’m just testing the new Rhino functions with Version 8
(8.0.23304.9001, 2023-10-31).
Undo not working suddenly and saying “Nothing to undo.”
While in “Multiple undo” there are a list of commands I’ve done.
But when I starts a new file it’s normal.
Any idea why?
Hi Tim - do these undo successfully?
Hi Pascal,
No, none of the undo’s work.
But now I can’t replicate the situation.
-Tim
Hi Tim -
A bug causing that behavior was found and fixed in 8.2.
RH-78325 Layer: Layers panel not ending undo record
Undos do not work across the board. If I delete an object it’s gone forever. The only things I can “undo” are those that I can retrace my steps using “opposite” commands (move, align, etc.).
I’m using the most recent R8 v. 8.8.24170.13002
Hi, same here. I’m running the 8.8 as well and undo is gone. I see that the bug is going on for quite some time now. Team please do something solid ! That’s a serious issue.
@Bob14 if this happens again, pls send your command history and _SystemInfo
There are a couple of cases reported of Undo stopping to work, I’ve run into it myself as well, but could not reproduce it by following the same steps. Difficult to reproduce also means hard to solve. If you have steps to reproduce or can indicate things you were doing before it stopped working, pls let us know.
Ok will do.
In the meantime I updated to 8.9 and it’s all fine so far.
I am also having this problem, it can only be solved by doing a save as and opening the previous save, often losing a lot of work. Over the last 2/3 weeks this is happening multiple times every day, I have since updated 2 new service releases and now have the latest one and the problem persists. Having used Rhino 4,5,6,7 and now 8, this is the first time I’ve seen this issue, but it doesn’t seem to be solved yet.
Same Here. If I make a change, it is permanent. I cannot undo it. This does not work well as I often try things to see how they look. FRUSTRATING.
