Thanks for adding the vector output to the technical view in Rhino 8.
I am wondering how the scale of the hidden lines can be adjusted?
In the viewport I get this appearance:
When I open the pdf I see only solid lines:
It would be helpful to have an option to print the lines as solid for better editing or dashed lines as direct output.
Anyhow it would be helpful to have the different line types on different layers in the pdf for better editing in illustrator if needed.
Tom
