I am working on a 3D model - and have produced a layout sheet with several detail viewports of the model with clipping planes. I have used various section styles on the layers, with different hatches & boundary widths. When I look at my model in the model space these appear good. When I look at this in the layout space with print preview on it also seems good. However when I export to pdf, all lineweights default to the same hairline. This problem doesnt seem to happen with curves within the model space but with the section styles and boundary thicknesses. I have tried Vecotr & raster, I have tried various formats PDF/ jpegs/ pngs - I have tried different display modes and still have no luck.
FYI i am running most up to date rhino 8 on a mac
Thanks!!
wim
(Wim Dekeyser)
December 9, 2024, 1:57pm
2
Hi Imogen -
Could you post a sample file and the output of the Rhino SystemInfo command? Depending on which display mode you are using for the details, printing to vector will behave as you describe. You should be able to get something out of raster mode.
Rhino Test.3dm (73.9 KB)
Rhino Test.pdf (4.0 MB)
Rhino 8 SR14 2024-12-2 (Rhino 8, 8.14.24337.13002, Git hash:master @ 93cb983e06fca769cb3c2f4783a3a42a3e127d4c)
License type: Educational, build 2024-12-02
License details: Cloud Zoo
Apple macOS Version 14.1.1 (Build 23B81) (Physical RAM: 32GB)
Mac Model Identifier: iMac20,1
Language: en-GB (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
AMD Radeon Pro 5500 XT (8 GB)
iMac (2560 x 1440)
C24-25 (1920 x 1080 @ 60.00Hz)
GPU Vendor: AMD
USB devices
TOSHIBA: External USB 3.0
Apple: Card Reader
CoreChips: USB 10/100 LAN
USB C : USB C Video Adaptor
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.14.24337.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.14.24337.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.14.24337.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.14.24337.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.14.24337.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.14.24337.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.14.24337.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.14.24337.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.14.24337.13002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.14.24337.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.14.24337.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.14.24337.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 8.14.24337.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.14.24337.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.14.24337.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.14.24337.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.14.24337.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.14.24337.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.14.24337.13002
Hi Wim
See rhino test above - it appears to be the same problem with every display mode that I try .
Thanks for your help !
Imi
wim
(Wim Dekeyser)
December 10, 2024, 10:06am
5
Imogen Dhesi:
Thanks, Imogen -
When I print that file to 600 dpi, the section hatches and the borders are basically invisible:
But when I print to 20 dpi, I get this result:
If you need higher resolution, you can increase the “scale” property in the print settings and/or use a layout that is smaller in size.
Thanks Wim, Carla also solved this bug and the newest rhino 8.15 has fixed it.
THanks!
