Rhino 8 Render Display Mode Issue
I’m having an issue with backface rendering in the Render Display Mode that started a few months ago but I’my only getting to posting about now. In my model, I added a number of landscaped plants to help preview what the space will look like for an architectural project. I produced them with the old school video game method of two perpendicular planes with a PNG image utilizing an alpha channel intersecting in the middle to give an approximation of 3D depth. It all looked great for a few weeks, but then one day I opened it and the transparency of the plants was totally screwed up. Suddenly all I see is the environmental background, or some of the other objects in the scene but they are in Arctic Mode, or something else entirely.
It’s not clear or consistent why this happens, except that I’m almost positive that it’s an issue with how transparency works with backfaces. Sometimes if I select an offending object the issue will go away and it will render correctly, only to return the moment I deselect the object. If I select all the objects (there are a few hundred), the issue goes away until I deselect them. I feel like I’ve looked at every possible button or option in the various options and settings, but maybe there’s something I missed. Please see the image attached. Has anyone else dealt with this issue or have any ideas?
Here’s my system info:
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13002, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Commercial, build 2024-03-12
License details: Cloud Zoo
Apple macOS Version 14.3.1 (Build 23D60) (Physical RAM: 32GB)
Mac Model Identifier: Mac14,5
Language: en-US (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M2 Max
Color LCD (1800 x 1169 @ 120.00Hz)
DELL S2421HS (1920 x 1080 @ 75.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/joshuasauerman/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp/DatasmithFacadeCSharp.dylib
/Users/joshuasauerman/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp/libtbbmalloc.dylib
/Users/joshuasauerman/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp “Datasmith Exporter” 5.2.1.0
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.5.24072.13002
Hi Michael -
Please post a simple 3dm file that shows the issue.
Hi @wim, here is a small portion of the file from my first post copied and pasted into a new file. The issue continues to appear for me. Let me know if you need anything else!
Render Display Mode Sample File 2.3dm (14.2 MB)
Thanks for that file, Michael.
That seems to be working fine on my end, though. Both on my current inhouse 8.8 and an older 8.5 version on macOS.
Your viewport is in the Rendered display mode when I open the file.
When you go to the Rhino Options → Display Modes → Rendered, and click the Restore Defaults button, does that make things behave better?
(Note, on macOS, you can’t tell if you have modified a factory-default display mode, and you might want to create a copy of that one if you think you have modified it…)
Hi @wim, Thanks for checking. I tried that yesterday and it didn’t do anything. Just tried it one more time, and still the same result. :man_shrugging:
Any other thoughts for troubleshooting?
@Michael_Mercadante the model you shared, does that show incorrectly on your machine as well?
When I open it on my M2 Max it shows up just fine in Rendered mode.
Hi @nathanletwory ,
Thanks for checking. Yes, here’s how it look on my computer:
I also just tried to make it a Double-Sided texture (I had tried Custom & Physically Based), but it still looks like this.
