Rhino 8 (MAC) - Display problems in one viewport
Hello everyone,
I have a small problem with the display in a viewport.
I have been using Rhino 8 (MAC) for a few days.
It’s probably just a setting that I accidentally changed with the wrong shortcut. But I can’t figure out how to solve it.
The objects are only not displayed in one view, so the layers are shown. It also doesn’t seem to have anything to do with the existing cropping layers. I have also checked the settings there.
I have also checked the Hide / Show command. Also Isolate / Unisolate…
I can’t find anything in the command history that puts me on the right track.
I have already closed and reopened the file, without success.
Unfortunately, I cannot describe the problem in more detail.
Does anyone know the problem or know a solution?
Best regards,
Marcel
Start Rhino, type _SystemInfo, and send the list here.
Rhino 8 SR1 2023-11-21 (Rhino 8, 8.1.23325.13002, Git hash:master @ 8a4a437248efac5d9cb04d3904481b83e4c23a64)
License type: Kommerziell, Build 2023-11-21
License details: Cloud Zoo
Apple macOS Version 13.0 (Build 22A380) (Physical RAM: 64Gb)
Mac Model Identifier: MacBookPro16,4
Language: de-DE (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5600M (8 GB)
Color LCD (2048 x 1280 @ 59.00Hz)
USB devices
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.1.23325.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.1.23325.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.1.23325.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.1.23325.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.1.23325.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.1.23325.13002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationsWerkzeuge” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Vorgänger Rhino-Renderer” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.1.23325.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.1.23325.13002
I would like to add another new insight.
It seems to be due to the viewport. If I change the views in it, e.g. to perspective or front, the geometries are not displayed there either.
However, in the display with the four viewports and the other preset views (top, front, perspective) the geometries can be seen.
I recommend to send your file to Rhino - Upload to Support
Hi Marcel -
It sounds like this is an issue with a single file only, is that right?
Have you checked the display mode in the viewport that is not showing geometry?
As Michael writes, if you can post or send the file, we can at least check if the issue can be seen on other systems.
Thank you both for your replies.
It seems to be a problem with the cropping Layers. I have old one from the RH7 File. In all views this are switched off. But if I delete rebuild a certain of them it works now. Very strange.
