Hi, I received 3D scans of boats and basically, I am tracing curves over the point cloud. It works well, but for some reason, every line that I draw in Rhino ends up showing very thick, especially when I zoom or move around my model, parts of the line appears big and other parts as a normal line thickness and it changes as I zoom or move. When I hide my ‘‘curves’’ layer, the background becomes fine again. If I change the color of the layer or lines, the background become that color. Can anyone help me figure out how can I have normal line thickness? My lines are setted to ‘‘hairline’’, so as small as possible. I did the reset command too, nothing changes. Rhino Tech Supports opened the files that I emailed them and it opens fine on their side. It does that on any file that I open. I use Rhino 8. Thanks!
Hi François,
Do you open a new Rhino file and import the point cloud data or open the point cloud file and trace in that?
Regards
Jeremy
Hi Jeremy, I received those 3D scans files from a company so I downloaded the files in my PC. I just clicked on the downloade file to open it. I am tracing on the point cloud received the company.
Thanks,
François
Hi François -
What happens when you don’t open a file that is provided to you but just launch Rhino and create a line?
In a file when you see this behavior, please run the Rhino SystemInfo command and copy-paste its output here.
Hi Wim, I just tried drawing lines in a new files and seems somehow fine, even if when I’m drawing, lines sometimes appears thick for a mili second. Maybe beacuse the file is really smaller than my point cloud. Here is the copy-paste from SyssyemInfo: Rhino 8 SR29 2026-3-4 (Rhino 8, 8.29.26063.11001, Git hash:master @ bbd126f84fcdaf7a974615b7c9f4f8667571c147)
License type: Commercial, build 2026-03-04
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 8GB)
.NET 8.0.14
Primary display and OpenGL: Intel(R) HD Graphics Family (Intel) Memory: 1GB, Driver date: 9-29-2016 (M-D-Y). OpenGL Ver: 4.5.0 NVIDIA 353.62
Integrated graphics device with 3 adapter port(s)
Primary OpenGL: Intel(R) HD Graphics Family (Intel) Memory: 1GB, Driver date: 9-29-2016 (M-D-Y). OpenGL Ver: 4.5.0 NVIDIA 353.62
Integrated (slow!) graphics device with 3 adapter port(s)
Secondary graphics devices.
NVIDIA GeForce 840M (NVidia) Memory: 2GB, Driver date: 7-22-2015 (M-D-Y).
Integrated accelerated graphics device (shares primary device ports)
- This device is not being used
ATTENTION:
Laptop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.5 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 7-22-2015
Driver Version: 10.18.13.5362
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.29.26063.11001
Hi François,
Your laptop’s graphics fall below the minimum recommended standard for Rhino. Apart from rendering though that may not be a show stopper. However, your video drivers are really ancient. Update them to the latest you can find for your machine. That could be a significant change.
Whilst your laptop’s memory meets the minimum standard for Rhino, I’d think about upgrading to significantly more if the video driver update doesn’t cure your problems.
