When the Osnap and SelectionFilter are both “docked” in two tabs to the left side (default), you can still make a tickmark next to Osnap in the container to the right (which show no tickmark next to Osnap even though Osnap is visible to the left). Is that the intended behaviour in 8?
And thanks @pascal. Another issue: right-clicking a selection filter no longer works. This should select only this filter, and deselect all other. Same behaviour as in Osnaps, where right-clicking still works.
Hi Duncan - right clicking does work as expected here. A right click sets the one filter, a second right click in the same checkbox reverts to the previous filter setting.
Yes I would very much like to have these two menus visible at all times on top of each other just as I had in Rhino 8. This new layout is just more work to see and more work to adjust these filters. 90% of my workflow in Rhino is muscle memory so fixing things that aren’t broken in the first place is not necessary.
I would love to see this fixxed in the next update so I can revert back to my old layout that I’ve been working with for over 10 years .
