Each time I select a Named View the list rearranges placing it at the end.
I don’t think this is supposed to happen…
Hi Bogdan -
I’m not seeing that behavior here. Can you please provide the SystemInfo data?
hi @wim , thaks for checking this.
I attached the file. It might be something related to the Named Views created by Clipping Sections.
I saw other problems related to them, like if I pan or zoom them and resave the Named View doesn’t save the new position correctly.
240324 Named views from Clipping Sections Rearrange.3dm (14.8 MB)
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13001, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Commercial, build 2024-03-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 31GB)
.NET 7.0.0
Primary display: AMD Radeon 780M Graphics (AMD) Memory: 1GB, Driver date: 8-9-2023 (M-D-Y).
- Windows Main Display is laptop's integrated screen or built-in port
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp "RhinoCodePlugin" 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
thanks for the report and file @Bogdan_Chipara
It looks indeed this is happening only with the named views generated by Clipping Sections.
RH-81284 Clipping Sections: Named view order
@Bogdan_Chipara
Digging further into the options, this seems to be the expected behavior when you set the Named View options for the view to restore clipping planes. When the ClippingPlane is restored, the associated Named View is recreated and hence the order changes (it is added at the end), but it retains its name.
If you uncheck, you will not see that behavior. Does that help?
When the ClippingPlane is restored, the associated Named View is recreated without changing the order. - should be better.
Sorting order might help you keep named views in place:
My humble opinion: Last created or recreated should be the last one on the list and if I want to rearrange, I can sort them manually by Name. This is how Layers also work.
@andy do you have thoughts about NamedViews order?
