Rhino 8 for Mac is confusing materials. Open the attached model and observe the materials on the walls. Commence orbiting and you should see the material change on some of the walls.
Hide the Layer WUpperRemove to see the correct material reinstated. Show WUpperRemove again and all should be OK. Orbit again to see the corruption.
If I rename the material Custom (4), the confusion seems to be corrected, but reappears on orbit.
If I rename the material Custom [imported] [imported], the confusion seems to be resolved. This is odd.
Command-Z to undo the renaming of the material reactivates the confusion. Redo to reapply the new name reinstates the correction.
Another observation is that selecting only unused materials in the list, then selecting all of those materials for deletion results in a warning message that indicates that the used materials are included in the deletion set. The Endeavour material is unused in the model, but I suspect that this problem only exists where the set of used materials are ‘buried’ within the overall list, with some unused materials before and after the used materials.
I’ve made a fix to Rhino that resolves this material flicker issue. It will be around a month before the fix will appear as a Service Release Candidate.
You can also fix the issue manually by modifying the color of the “Custom [imported] [imported]” material (the first one in the list of materials). You can change the color only slightly and the issue will resolve itself. The problem was that, somehow, the color of the material wasn’t set up properly. Let me know if this fixes the issue for you.
It would be interesting to know from where you originally imported the material. Knowing this, we might be able to reproduce the material color import issue.
@DavidEranen I have been applying the colour tweak to various models, and found a twist. In the full models, as opposed to the partial model that I attached, after I tweaked the colours in all [imported] materials, I also had to tweak the colour of the Internal Walls material. That material does not have the [imported] attribute.
