Hi there,
it seems all my ctrl-based shortcuts are gone and I can’t create new ones. Can anybody help me restore them?
Thanks a lot,
Sebastian
Hi there,
Thanks a lot,
Sebastian
Also, I am unable to turn off the projected mode. Suddenly there are strange shortcuts that do all kinds of things I never used assigned to shortcuts I used to have before. It seems my copy of Rhino is unusable. Since I am in a very busy state in a project, where I need this thing to work, does anybody have an idea what to do?
Tried a new installation, same result.
I used to love Rhino, with Rhino 8 it changed a bit and right now I start to feel a strong dislike. As countless others in the forums I think this version is very unreliable… :-/
Hi Sebastian -
Please start by running the Rhino SystemInfo command and copy-paste the output here.
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07002, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Commercial, build 2024-10-08
License details: Cloud Zoo
Apple macOS Version 12.7.6 (Build 21H1320) (Physical RAM: 64GB)
Mac Model Identifier: MacBookPro16,1
Language: en-GB (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5500M (8 GB)
Color LCD (1792 x 1120 @ 59.00Hz)
BenQ LCD (2560 x 1440 @ 60.00Hz)
GPU Vendor: AMD
USB devices
Western Digital: Elements 25A1
Apple, Inc: Apple Keyboard
Tablet: PTK-840
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.12.24282.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.12.24282.7002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.12.24282.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.12.24282.7002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.12.24282.7002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.12.24282.7002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.12.24282.7002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.12.24282.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.12.24282.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.12.24282.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.12.24282.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.12.24282.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.12.24282.7002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.12.24282.7002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.12.24282.7002
Thx for looking into it btw ![]()
This is one of the things I do like very much about Rhino. You McNeel people look through here and help people a lot.
Hi Sebastian -
Testing this in the version of Rhino that you are running, I’m seeing this:
Does nothing at all happen on your side?
I can go that far, but no further. It will not execute any command I was assigning to that shortcut.
Yet another thing, sometimes I can’t turn layers on or off in details in the layout. But one thing at a time. My workflow relies heavily on shortcuts.
Hi Sebastian -
Thanks for reporting this. I’ve put it on the list as RH-84540 Keyboard Shortcuts: Control Doesn’t Work
Yes, pls make a new thread for this, thanks!
RH-84540 is fixed in Rhino 8 Service Release 14
Hm…still doesn’t work here. Tried to create new ones as well as changing existing shortcuts. Neither are saved after closing and reopening Rhino.
did you install a service release candidate not the regular service release? you can change the frequency in the settings under general. i did not try the new update yet but i gave up on modifying shortcuts earlier due to them being half baked
my bad, just installed the normal update.
Tried the SR candidate, doesn’t even accept ctrl…
Hi Sebastian -
Could you provide more information here?
Post the updated `SystemInfo´ output and somewhat more details about what you are doing.
Rhino 8 SR14 2024-11-12 (Rhino 8, 8.14.24317.14002, Git hash:master @ 69ab12ed53cf1e6d17f23ab5fec3c3f7216df72d)
License type: Commercial, build 2024-11-12
.NET 7.0.0
Graphics processors
GPU Vendor: AMD
USB devices
GenesysLogic: USB3.1 Hub
Tablet: PTK-840
Apple: Headset
Bluetooth devices
None
None
Third party plugins
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.14.24317.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.14.24317.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.14.24317.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.14.24317.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.14.24317.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.14.24317.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.14.24317.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.14.24317.14002
I was trying to generate new/edit existing shortcuts using the ctrl button. Before SRC14, with the regular release Rhino accepted the ctrl button but wouldn’t do anything, after I installed SRC14 the shortcut editor does not accept the ctrl button. It doesn’t change anything. In fact I can’t edit/add/change any shortcuts using any buttons anymore.
