Hallo,
can it be that the latest Update disabled the loading of all Plugins in Rhino ?
In Grasshopper i can see my Plugins, but in Rhino they are all not visible, but installed, also with Commands i cant see any.
ggRhinoIFC: for example
Thanks for your time.
Japhy
(Japhy)
July 8, 2026, 11:06am
2
It sounds like you are opening in Safe Mode. Please run SystemInfo in the rhino command line and post the results
Japhy:
SystemInfo
Rhino 8 SR33 2026-6-17 (Rhino 8, 8.33.26168.09001, Git hash:master @ 2ded7b8c3751efbca7caacdffcbe8f8c60fb77b8)
License type: Commercial, Build 2026-06-17
Windows 11 (10.0.22635 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.28
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 1-15-2026 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
Secondary monitor is laptop’s integrated screen or built-in port
Secondary monitor attached to adapter port #1
Windows Main Display attached to adapter port #2
Primary OpenGL: NVIDIA RTX A2000 8GB Laptop GPU (NVidia) Memory: 8GB, Driver date: 11-18-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.95
Integrated accelerated graphics device (shares primary device ports)
Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-18-2025
Driver Version: 32.0.15.8195
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\RhinoUser\AppData\Local\Programs\UNIFI Labs\Rhino\UnifiLabs.RhinoAddin.rhp “UNIFI Rhino Plug-in” 0.0.2.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.33.26168.9001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “LeerlaufProzessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.33.26168.9001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.33.26168.9001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.33.26168.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.33.26168.9001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.33.26168.9001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.33.26168.9001
Japhy
(Japhy)
July 8, 2026, 11:47am
4
Nothing unusual there, lets try repairing rhino (add remove programs, right click rhino, modify, repair).
If that doesn’t do it we should check to see if the previous version does resolve it.
wim
(Wim Dekeyser)
July 8, 2026, 1:41pm
5
Also, make sure that the plug-ins are enabled in the Plug-in Manager.
The following Version of ggIFCRhino is working.
"ggRhinoPlugin, Version=26.5.14.8, Culture=neutral, PublicKeyToken=null Version 26.5.14.82
