I keep getting this error, I’ve tried everything but I can’t solve it. Can you help me?
Are you running Rhino in Safe mode per chance?
You can go into Properties>Plugins and enable it if that is not the case.
No, I’m opening it as a normal Rhino 8, but even when I activate Grasshopper from here, I still get the same error.
What is your Rhino SystemInfo? (run the command in Rhino)
Lets repair your Rhino install. Go to Add Remove Programs / Rhino / modify / Repair
I’ve tried repairing it multiple times, but it still hasn’t fixed the problem. It was working perfectly until today, but I started getting this error when I turned it on.
Rhino 8 SR27 2026-1-19 (Rhino 8, 8.27.26019.16021, Git hash:master @ a7029e543145704b986eede4bc40b6bd8a0645d0)
License type: Educational, build 2026-01-19
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 16GB)
.NET 8.0.15
Primary display and OpenGL: Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 6-19-2024 (M-D-Y). OpenGL Ver: (null)
Integrated graphics device with 4 adapter port(s)
Secondary graphics devices.
NVIDIA GeForce RTX 4050 Laptop GPU (NVidia) Memory: 6GB, Driver date: 12-30-2025 (M-D-Y).
Integrated accelerated graphics device with 4 adapter port(s)
- This device is not being used
ATTENTION:
Safe Mode is enabled. Graphics device usage and OpenGL information cannot be collected.
OpenGL Settings
Safe mode: On
GPU Tessellation is: On (but disabled due to other settings)
Graphics level being used: OpenGL (null) (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 12-30-2025
Driver Version: 32.0.15.9174
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: 16777472 x 16777216
Total Video Memory: 6141 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.27.26019.16021
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.27.26019.16021
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.27.26019.16021
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.27.26019.16021
You are in safe mode.
You also want your Nvidia to the primary OpenGL
I turned off safe mode, this is probably the problem, and I’m trying what you sent right away. Thank you.
.NET 8.0.15
Primary display: Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 6-19-2024 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4050 Laptop GPU (NVidia) Memory: 6GB, Driver date: 12-30-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 591.74
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Z-Buffer depth: 24 bits
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\omert\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.4.2.0
C:\Users\omert\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.27.26019.16021
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.27.26019.16021
@Japhy I’ve tried everything, but I’m still getting the same error.
So not in Safe mode and you are still not able to enable the Grasshopper plugin?
Lets disable 3rd party plugins and restart Rhino.
Unfortunately, it didn’t work. Should I uninstall and reinstall it?
A repair is better, so not likely to get a different result, unless there are some permission issues that are blocking the file. Uninstall and reinstall as Admin is worth a try.
Thank you for your time.
