Thank you Steve, will do now.
rhinotrace.json (4.5 KB)
Thank you,
Steve
Is there a repository of older versions of r8 that i can install until i find a working version?
Iâll send you some links, please let us know which one is working for you. Thanks
Thank you Japhy!
I just tried version ârhino_en-us_8.0.23304.09001â from a coworker and it has NO lag at all.
Hopefully the difference between these two might help.
PS: is there a way to prevent the âdownload new version messageâ?
Thank you
I would much rather get you on a more recent build than 8.0 as there are a large number of bug fixes for other issues since that release. Japhy will send you links to more recent builds.
Thank you, I would as well.
v8.5 is running best on my system. (lag free)
Does that mean that the problem started in 8.6?
On my system, it appears to be the case. I was out of the office for about 3 months and didnt notice the problems introduction until i returned and jumped several versions during the update cycle. .
Steve,
Any more insights into a fix for the r8 slowdown on startup?
I installed the latest version available 8.10.24288.13001 and noticed that when I start in SAFE Mode and âdragâ files from explorer into Rhino Safe Mode I have NO lag problem. The software is very fast when doing this. ZERO lag.
I do get this warning however
Any ideas why this is working so well but running in normal mode has a 10sec lag event, still?
Hi Japhy,
Installed version rhino_en-us_8.11.24254.15001 today.
Same lag issue.
Walt
This is a major clue, particularly since your previous systeminfo didnât show any 3rd party plugins.
Safe mode is disabling non-critical plugins (3rd party and native) as well as minimal graphics processing.
When are you seeing the warning?
We can disable plugins via File>Properties. Close the file and reopen. You can do this in Standard Rhino or SafeMode.
Thank you Japhy, found the culprit. It is â3Dconnexion 3D Mouseâ.
Once turned off the software has no lag on startup.
The Spacemouse version im using is:
Rhino 8 SR11 2024-9-10 (Rhino 8, 8.11.24254.15001, Git hash:master @ d3c11108eae09fadc146928ba51b9b182a05303f)
License type: Commercial, build 2024-09-10
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.20
Primary display: Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 5-12-2024 (M-D-Y).
- Laptop lid is possibly closed
- Windows Main Display attached to adapter port #1
- Secondary monitor attached to adapter port #2
Primary OpenGL: NVIDIA RTX 4000 Ada Generation Laptop GPU (NVidia) Memory: 12GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.86
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-23-2024
Driver Version: 31.0.15.5286
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp âCommandsâ 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\import_ACAD.rhp âAutoCAD file import: import_ACADâ
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp âMeshCommandsâ 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp âDisplacementâ
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp âSectionToolsâ
Hi Japhy,
I removed the current 3D Spacemouse driver and installed an older version
from 2023. It also has the lag now (did not have the lag in 2023 with either 3dconnexion or Rhino).
In your opinion, is the lag coming from the recent Rhino 3Dconnexion plugin?
Thank you,
Walt
That is a plugin that ships with Rhino, @dale should have some insights.
I donât have much to add here.
I have a SpaceMouse Enterprise. With it connected, Rhino 8 for Windows opens the .dwg file you posted nearly instantaneously.
â Dale
Im using the Spacemouse Pro. It has a 10sec lag on startup of any and every file I open.
Without the spacemouse itâs relatively instant.
NO other program I use the space mouse with has this lag, except for Rhino 8.
Autocad and 3DsMax work the way Rhino 7 and early versions of Rhino 8 did.
As Rhino 8 is my primary tool this has become very frustrating, on a daily basis.
