We generally open and create DWG files created in Rhino.
The latest version of r8 is very slow to open. As we are expected to open, close and create a large number of files in any given day, this is causing a lot of frustration.
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.20
Primary display: Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 5-12-2024 (M-D-Y).
- Secondary monitor attached to adapter port 1
Primary OpenGL: NVIDIA RTX 4000 Ada Generation Laptop GPU (NVidia) Memory: 12GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.86
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-23-2024
Driver Version: 31.0.15.5286
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
Model space objects read: 1, skipped: 0
Paper space objects read: 0, skipped: 0
Block definition objects read: 0, skipped: 0
XRef objects read: 0, skipped: 0
Successfully read file “C:\Users\WClisham\OneDrive - Global Furniture Group\Desktop\Test_01.dwg”
(0.0000) - Since Last Record = 0.0000 (%0.00) - Create Stopwatch
(2.5730) - Since Last Record = 2.5730 (%31.80) - after create and load AppSettings
(2.5730) - Since Last Record = 0.0000 (%0.00) - before CRhWGLExtensions::InitWGLExtensions()
(3.8110) - Since Last Record = 1.2380 (%15.30) - after CRhWGLExtensions::InitWGLExtensions()
(3.8230) - Since Last Record = 0.0120 (%0.15) - construct CMainFrame
(5.6340) - Since Last Record = 1.8110 (%22.38) - after load CMainFrame
(6.0380) - Since Last Record = 0.4040 (%4.99) - after initialize license manager
(6.0400) - Since Last Record = 0.0020 (%0.02) - after log events
(6.0400) - Since Last Record = 0.0000 (%0.00) - after registering shell file types
(6.0400) - Since Last Record = 0.0000 (%0.00) - before loading of cursor resources
(6.0510) - Since Last Record = 0.0110 (%0.14) - after loading of cursor resources
(6.0710) - Since Last Record = 0.0200 (%0.25) - after RegisterBuiltInCommands()
(6.1030) - Since Last Record = 0.0320 (%0.40) - Pre auto load plugins
(6.1290) - Since Last Record = 0.0260 (%0.32) - Toolbars
(6.1360) - Since Last Record = 0.0070 (%0.09) - RDK:CRhRdkRhinoPlugIn CTOR
(6.1370) - Since Last Record = 0.0010 (%0.01) - RDK:OnLoadPlugIn
(6.1390) - Since Last Record = 0.0020 (%0.02) - RDK:Initialize: start
(6.1390) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after default registered properties
(6.1470) - Since Last Record = 0.0080 (%0.10) - RDK:Initialize: after default post effect plug-in factories
(6.1470) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after adding internal extensions
(6.1470) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after conduits
(6.1590) - Since Last Record = 0.0120 (%0.15) - RDK:Initialize: end
(6.1590) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK Initialize
(6.1590) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK OnLoadRhinoPlugIn
(6.1620) - Since Last Record = 0.0030 (%0.04) - RDK:OnLoadPlugIn - end
(6.2190) - Since Last Record = 0.0570 (%0.70) - Renderer Development Kit
(6.4130) - Since Last Record = 0.1940 (%2.40) - Commands
(6.4290) - Since Last Record = 0.0160 (%0.20) - Snapshots
(6.4450) - Since Last Record = 0.0160 (%0.20) - Rhino Render
(6.5250) - Since Last Record = 0.0800 (%0.99) - RDK_EtoUI
(6.5450) - Since Last Record = 0.0200 (%0.25) - MeshCommands
(6.6540) - Since Last Record = 0.1090 (%1.35) - RhinoCycles
(6.6910) - Since Last Record = 0.0370 (%0.46) - 3Dconnexion 3D Mouse
(6.7060) - Since Last Record = 0.0150 (%0.19) - Displacement
(6.7230) - Since Last Record = 0.0170 (%0.21) - SectionTools
(6.7240) - Since Last Record = 0.0010 (%0.01) - Start of C# Rhino.UI.TabPanels.NamedCallbacks.RestoreTabPanelCollections
(6.7240) - Since Last Record = 0.0000 (%0.00) - End of C# Rhino.UI.TabPanels.NamedCallbacks.RestoreTabPanelCollections
(6.7240) - Since Last Record = 0.0000 (%0.00) - after create TabbedDockBarCollection
(6.7250) - Since Last Record = 0.0010 (%0.01) - after load default render engine
(6.7250) - Since Last Record = 0.0000 (%0.00) - after CloseAllDocuments
(6.7470) - Since Last Record = 0.0220 (%0.27) - before LoadToolBarsAndRestoreDockBarPositionAndStates
(6.7490) - Since Last Record = 0.0020 (%0.02) - Start of C# Rhino.UI.TabPanels.NamedCallbacks.LoadInitialToolBars
(7.0330) - Since Last Record = 0.2840 (%3.51) - End of C# Rhino.UI.TabPanels.NamedCallbacks.LoadInitialToolBars
(7.0330) - Since Last Record = 0.0000 (%0.00) - after m_pCallbacks->LoadToolBarFiles
(7.0330) - Since Last Record = 0.0000 (%0.00) - after RunLoadToolbars
(7.3920) - Since Last Record = 0.3590 (%4.44) - after RunPostLoadToolBarsAndRestoreDockBarPositionAndStates
(7.3920) - Since Last Record = 0.0000 (%0.00) - after LoadToolBarsAndRestoreDockBarPositionAndStates
(7.3920) - Since Last Record = 0.0000 (%0.00) - before Process Shell Commands
(7.4170) - Since Last Record = 0.0250 (%0.31) - AutoCAD file import: import_ACAD
(8.0910) - Since Last Record = 0.6740 (%8.33) - after Process Shell Commands
(8.0910) - Since Last Record = 0.0000 (%0.00) - CRhStopWatch::ShowReport()
Is the test to start a new instance of Rhino and open a dwg file or are you seeing things being slow with an already open copy of Rhino that you are constantly opening different dwg files from?
I’m still unsure if you are including the start up time for Rhino in the description of your problem. If you start Rhino and open a file, then open another file without restarting Rhino. Is there a long delay?
