Rhino 8 - Gumball/CPlane issues
Since upgrading to Rhino 8 I’ve been having issues with the CPlane/World of the gumball constantly changing to be incorrect. I haven’t been changing the CPlane, just moving between the four default viewports (Perspective, Top, Right, Front)
I don’t have Auto CPlane turned on and I’m just so perplexed as to why this is happening. Even if I try to reset the CPlane or even reset the World axis, the Gumball still displays an incorrect CPlane until I close the file and reopen.
Attaching a screenshot of an example of what the Gumball is displaying, in Right viewport. The gumball seems to be on a tilted axis rather than the World or CPlane.
Any suggestions??
EDIT: To also add, why is the gumball not centered on an objects centroid anymore?
Hi Mitchell - can you please run SystemInfo in Rhino and copy/paste the results? Can you also post a simple file that shows this, or send to tech@mcneel.com, with a link back to this topic in your comments?
Ok please find the System info below, along with a file and photo attached. Even with CPlane → World → Top, it still gives the CPlane as off at an angle.
Rhino 8 SR6 2024-4-10 (Rhino 8, 8.6.24101.05001, Git hash:master @ 32c244aa711e0034e75bec2e87d093c764820b96)
License type: Commercial, build 2024-04-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3080 (NVidia) Memory: 12GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24101.5001
CPlane or World Issues.3dm (1.9 MB)
Hi Mitch - GumballReset will sort these out.
Ok thanks, just tried that and it worked, but I have to reset it for each object? Any reason what is causing them to need to be reset? I haven’t changed any of my modeling workflow from Rhino 7 to 8, but getting very different Gumball behavior.
Thanks again for your help.
EDIT: Just to add, by modeling workflow, I meant that I am mostly just using the default viewports and their default CPlanes. So I don’t know what is causing objects Gumballs to have random CPlanes.
Hi Mitch - I do not know how it got that way - in your example file it seems all of the objects with wonky gumballs have them oriented the same way- where do the boxes come from? Does this misalignment happen other than in this case? Can you reproduce it?
Hi Pascal,
Sorry for the delay in getting back to you. I’ve been working through various projects at work using Rhino 8 and I’ve yet to figure out what causes the issue. It doesn’t happen often, but every now and then it will. Reset gumball fixes it. I’ll keep looking out for when it happens and to see if I can figure out the trigger. Surprised no one else seems to be having this issue.
I am having this same issue and gumball reset doesn’t work.
+1 here… since the last 2 updates
@user384 @nachetz
there are two different issues discussed here. The change in behavior of Gumball and Reset not working. If you have a sample object where AutoReset or Gumball Reset doesn’t work, pls share the model.
Also pls post the result of _SystemInfo, thanks.
