hello @TTB can you run _SystemInfo and post back the result?
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15001, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Evaluation, build 2024-01-09
License details: Stand-Alone
Expires on: 2024-04-17
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
.NET 7.0.16
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 12-21-2022 (M-D-Y).
- Secondary monitor attached to adapter port #2
Primary OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 11-21-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.26
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-21-2023
Driver Version: 31.0.15.4626
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.24009.15001
@DavidRutten do you know what the above error can be caused by?
Not Really , This was the first time that I was running R8 …
I have both R7 and R8 installed
R7 is a commercial licence with my company and R8 is an evaluation
R7 uses the company email address for the registration
R8 uses another email address for evaluation purpose
other than that I am not sure why this error is popping up
@TTB the question I asked is directed at David Rutten, unfortunately I have no solution for the error you posted.
There are no types in Grasshopper whose name is the broken heart emoji. To figure out which plugin is causing this problem the best way is to run the _GrasshopperLoadOneByOne command at the start of a fresh Rhino. Do not load certain plugins to see whether the problem goes away. Then at least we’ll know which component plugin is responsible.
It’s a slightly weird error in that when Grasshopper loads it also tries to instantiate each object, so if that was going to fail I’d expect it to fail at load time, not at double-click-search-for-components-manually time.
Thank you @DavidRutten @Gijs for attending my Query
The problem was resolved with the “_GrasshopperLoadOneByOne” command
Regards
Did you identify the culprit?
It seems like the “Karamba3D” plugin caused the error , however I am not entirely Sure TBh
