Rhino 8 DXF import/export speed
Since I upgraded to Rhino 8 i started having troubles with importing and exporting DXF files. The import and export speeds are very low compared to Rhino 7. I even tested the same files on the same computer, opened simultaneously in RH7 and RH8, and when I export the same 2D drawing, RH8 is much slower than RH7, all settings the same. Same problem is on importing too. Did anybody else encounter this problem?
I have been experiencing this issue as well, but with FBX file imports and also tested it with Rhino 7. I had a 300 MB file import into Rhino 8 over the weekend for ~72 hours with no luck. I tried the same file in Rhino 7 and it imported within 24 hours. Not sure what the deal is.
