Hello Everyone,
Importing a dwg or a dxf with Rhino 8, single line text that was created exporting the file from Rhino 8 disapears.
These text objects show up juste fine when importing with Rhino 7.
R8:
R7:
Hello Japhy,
Here is Systeminfo:
Rhino 8 SR11 2024-9-10 (Rhino 8, 8.11.24254.15001, Git hash:master @ d3c11108eae09fadc146928ba51b9b182a05303f)
License type: Commercial, build 2024-09-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Primary display and OpenGL: NVIDIA Quadro T1000 (NVidia) Memory: 4GB, Driver date: 6-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.78
Primary OpenGL: NVIDIA Quadro T1000 (NVidia) Memory: 4GB, Driver date: 6-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.78
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-15-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-10-2024
Driver Version: 31.0.15.3878
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\SimLab\Plugins\SimLab VR from Rhino\SimLabVRPlugin.rhp “SimLab VR for Rhino”
C:\Program Files (x86)\Evolute\EvoluteTools D.LOFT Evaluation for Rhino 6\EvoluteCoutHook.rhp “EvoluteCoutHook”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\export_ACAD.rhp “AutoCAD file export : export_ACAD”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24254.15001
Also find the file in question:
shell_235.dxf (185.8 KB)
I am seeing a similar result on the import (no text).
What setting did you use on export? Can you post the original file as well? Thanks
Hi Japhy,
It is the original file as it is created thru a grasshopper script that decomposes a boat structure into individual parts for cutting.
I am using the elefront export generic block.
Trying to identify the pattern to make a youtrack RH-84045. I need steps the developer can repeat.
Seeing some odd behaviors.
Sometimes in a new instance of Rhino insert the .dxf works fine, if not reinserting does show the text. In the same instance create a new file, open or import works fine. I might have to go with that for the bug report and see what they say.
RH-84045 is fixed in Rhino 8 Service Release 20
