ed.p.may
(Ed P May)
#1
After update to Rhino 8.0.22109.08306, 2022-04-19 the DXF import does not work on Mac OS.
DXF file imports fine in Rhino-7:
but exact same DXF import fails in Rhino-8
Environment:
- Macbook 2021, Apple M1 Max
- OS 12.3.1 (Monterey)
- Rhino Version 8 WIP (8.0.22109.08306, 2022-04-19)
all the best
@ed.p.may
wim
(Wim Dekeyser)
#2
Hi Ed -
Does that also fail when you draw a simple rectangle in Rhino, export that to DXF, and then import that DXF file back into Rhino?
ed.p.may
(Ed P May)
#3
Hi @wim
Yes, afraid that gives me the same error:
I also tried saving that as different DXF and DWG formats (years) and all give me the same error.
best,
@ed.p.may
wim
(Wim Dekeyser)
#4
Hi Ed -
Could you run the Rhino SystemInfo
command and copy-paste that here?
ed.p.may
(Ed P May)
#5
Hi @Wim, sure thing: Rhino 7 and 8 files attached here.
best
@ed.p.may
Rhino_7_SystemInfo.txt (4.0 KB)
Rhino_8_SystemInfo.txt (4.5 KB)
