I have downloaded and installed Rhino 8 application from https://files.mcneel.com/dujour/exe/20231031/rhino_en-us_8.0.23304.09001.msi on Windows 10 x64 VM. While launching shortcut I get
I have installed .NET framework 4.8.1,and visual C++ redistributable (2010,2013 and 2015-2022).but the error still persists. Also tried repairing application from control panel and rebooting the machine but the error still persists.
Can anyone guide what is going missing during pre-install/post-install?
I installed Dot Net Core 7 but the error still persists. Here is the list of applications installed on the machine. The build is clean and has only Rhino8 installed.
I think the only thing I can offer is to try starting Rhino 8 with
/netfx as part of the command line.
(either manually on a command line or via copying or editing a shortcut)
Since Rhino 7 is running, it seems like 4.8 should be working.
